+9v and -9v from a single battery - what's the best way to do it?
Started by alparent, February 11, 2009, 08:51:29 AM
alparent
This is my first post on this forum (I just joined 2 days ago) and I already learned a lot!
After searching this site and others I've found 3 ways of getting -9v from a single battery:
1. Using the MAX 1044 chip
2. Using the ICL7660
3. Using a 555 timer
I really need your advice on witch method is best and why.
(If there are other methods.........feel free!)
  MAX1044 is a 'good' way..
alex frias
I thought ICL7660 and MAX1044 were the same device...
Pagan and happy!
7660 is good - but it uses a switching frequency in the audio range, so this usually makes a detectable whine in pedals using it.
MAX1044 is pin-for-pin compatible with the 7660, but when you connect pin 1 and pin 8, it raises the switching frequency above audio, so any whine cannot be heard.
LT1054 is pin-for-pin compatible with the 7660 and the MAX1044, but it allows an input power supply of up to 15V; the 1044 is 10.000000V max, which is tight in a 9v setup where a fresh alkaline battery may be 9.3-9.5V and there are techo-guys with BUMS who may just want to stick 12-18V into a pedal to see if it sounds better somehow. The LT1054 will be more durable, and switches above audio too.
gez
Edit: Scratch...wasn't thinking.
Andi
alparent
Just to had another twist to my question.
Is it better to use 2 batteries (if I have the space) or does it make any difference?
Quote from: Andi on February 11, 2009, 12:11:56 PM
I thought the 7660 had a boost function too.  ???
No boost on the 7660.
Microchip TC1044SCPA or the TC1044SEPA are cheaper than MAX1044 (and LTC1054) and go up to 13 volts.
Topic: Cheaper, (possibly) better MAX1044 alternative with boost:
http://www.diystompboxes.com/smfforum/index.php?topic=73759.msg598509#msg598509
Quote from: alparent on February 11, 2009, 12:42:57 PM
I'd go with a charge pump rather than two batteries - unless the application is drawing loads of ma.
Andi
