12v through audio jacks?
Started by 347sixtyseven, February 12, 2009, 07:24:40 PM
347sixtyseven
Hi guys,
Just wondering if it is ok to run 12v dc through audio jacks?
I am building a power supply with 5 outputs of 12 v at 500 mA and i am very limited space-wise for the sockets.
I was thinking of using the small mono audio jacks instead of the normal dc in jacks.
Cheers
Gary
WLTerry
Yes it's possible... like the old DOD stompboxes, there's should not be major problem.
Will
347sixtyseven
The only bad thing is that as the tip is +ve it will short to the socket if you plug it in when switched on - sparks will fly.
kurtlives
^use a insulated jack then. Simple and cheap.
My DIY site:
www.pdfelectronics.com
347sixtyseven
Would shorting be an issue if i used rca plugs instead?
