Rangemaster Noise. (Positive vs. Negative Ground)
Started by sevenisthenumber, February 17, 2009, 05:49:15 PM
sevenisthenumber
I built a positive ground and negative ground on vero (both using oc44's) and the negative ground is way more noisy. Does any one have knowledge of why? :icon_question:
  Only possible why's are possible with what we have here.
1  Transistor is a noisy one?
2  Some other reason.
  1 If you socketted it's pretty easy to try different transistors, if not the leakage/gain circuit for testing Ge's might tell you something.
  2 A once reverse polarized cap, something with the PS, is about all I can think of, off the bat, I would try to nail #1 down further if everything else is exactly the same except the polarities.
