Help with noise(hiss) in EQ build
Started by RonaldB, March 12, 2009, 05:00:35 AM
RonaldB
Hello,
I'm building an EQ. It's a combination of the GGG eq and the GE-7 (boss).
I have drawn this schematic:
http://img25.imageshack.us/img25/8964/48750931.png
It works fine and boost all the frequencys I want, but there is a terible hiss. It's not a ground hum.
I tried severall thing and here's what I came up with. When I detached the eq section the hiss is gone.
When I add one EQ stage there is some hiss and it gets louder when i turn the knob to boost.
When I connect more EQ stages there is more hiss.
I have used mylar caps for the EQ stages and not tant caps(as posted in the GE-7 schematic).
http://www.schematicx.com/schematic/boss-ge-7-equalizer-pedal-schematic/
So what's the dela here, can somebody point me in the right direction to solve this hiss problem.
Ronald
alanlan
I think there are some mistakes in your circuit diagram.  The first thing to ask is: have you made the same mistakes in your actual circuit - I haven't time to check everything right now but the non-inverting inputs are not biased as per the original circuit for one thing - please check everything and if there are still problems get back.
RonaldB
well that's not the problem. It's biased correctly like it should.
I use a biopolar powersupply style.
alanlan
So, the + inputs of IC2, 3 and 4 are not wired as per your circuit diagram?
