Old PT2399 Delay Layout ?
Started by Stomp, March 23, 2009, 04:34:59 PM
Stomp
Im gonna try my first attempt at a delay pedal, & just picked this one, based off this schematic, adding the charge pump to run off 9v.  Hoping someone could review & give me a heads up if I made anymistakes, or things to look for when I go to build.  Laid this out for point to point on a perfboard (yes I'm cheap & works for me).  I use a number system for wire connections.  Not perfectly to scale, part sizes are based on what I have on hand.  Thanks in advance for any help.
schematic:  http://www.generalguitargadgets.com/diagrams/pt80schem.pdf
layout:  http://i204.photobucket.com/albums/bb235/whathefuk_photos/PT2399DELAYJPG.jpg
Thomeeque
I'd say this circuit will eat too much to be powered by 9V battery (even the Vref divider by itself eats more than some pedals /6mA/, it's obvious, that it was designed as wall wart powered effect).
Do you have a technical question? Please don't send private messages, use the FORUM!
Stomp
I can try it, if it dont work out, I should be able to  take out the charge pump  & battery connector & convert it to use a walwart, & not  affect the rest of the circuit.  Thanks for the heads up though!
