bass/treble cut switch
Started by 1878, March 23, 2009, 06:11:59 AM
Hello...
I need a simple bass/treble cut switch for a fuzz I'm building. Does anyone know of an easy solution to get me started ?? I don't mind having two switches on the pedal (there's more than enough room) so the simpler the better for now.
Thanks everyone.
1878
GibsonGM
Try it out, should be cool - I would put it just before (can be just after, too) my output cap...when the .005 cap is 'in', it will work in series with the output cap so you'd get a cap value of:  C1XC2/C1+C2, or .005 X output cap/.005 + output cap.
If you can, try adding caps in series w/your output cap on a breadboard til you find the winning combination, then solder the cap in to the switch; it is a lot easier that way ;o)
If it doesn't do what you want, you'd have to get more sophisticated, but many find this way easiest and effective.
1878
Cheers.
It's a similar idea to the bass cut on my Jaguar. I'll solder a socket to try my caps.
Thanks again.
