2 SAD512s = 1 SAD1024?
Started by jdub, April 02, 2009, 04:57:56 PM
jdub
Hello all-
Searched the forum & couldn't find any specific info on this: Does anyone know how to wire up 2 SAD512s (the 16-pin versions) to perform the function of 1 SAD1024? I've heard of this being done, but haven't been able to find guidelines.  I'm not really all that hip on BBDs, but I have a general idea of how they work (clocking, etc.)...
Since the 16-pin SAD512s are pretty much 1024s with a non-functioning B-side, would this process entail splitting the pinout of the 1024 between the two 512s (i.e., match B-side pinout of 1024 to the corresponding pns on the 512)? Since the two sides of a 1024 share Vdd, gnd and (I think) Vbb, I assume that these pins on the 512s would have to be individually connected- that is, each 512 would have to connect to Vdd, gnd & Vbb, correct?  I would like to use these in (what else?) a 9v Electric Mistress, if it can be done, since I have 'em laying around.  Any pointers would be much appreciated. Thanks!
A boy has never wept nor dashed a thousand kim
StephenGiles
Sledgehammer to crack a nut. Buy the SAD 1024 from Smallbear and save yourself a lot of hassle.
dthurstan
I don't know alot about BBD Tech, but what you want to do is called cascading. I asked about cascading any bbds and oldschoolanalog replied with some great links.
http://www.diystompboxes.com/smfforum/index.php?topic=73962.msg600553#msg600553
Check out the generalguitargadgets.com link. It shows how to connect to MN32XX type chips. I guess if you see how thoses 2 chips are connected you can figure
out how the two SADs connect!
Hope this helps.
Dave
jdub
Stephen, buying a 1024 from Small Bear (or anyplace for that matter) would definitely be my first choice, but Steve apparently doesn't have them for sale anymore- I couldn't find them in his stock list, anyway-and I haven't been able to locate them anywhere else except through parts locators with (at least) $300 minimum purchases. Plus, I'm kind of interested in seeing if I can get it to work, just for fun (and since I have the parts).  I appreciate the suggestion, though!
Thanks much for the link(s), dthurstan- it would have helped if I'd used the poper search term, I guess!  I'll dig through this stuff and see if I can suss it out.  My gratitude for the help, guys.
Quote from: jdub on April 02, 2009, 04:57:56 PM
Yeah, it probably works. At least in the cascaded modes. The results in the interleaved modes might depend on side-to-side matching to get minimum distortion. That may need different tweaking per side, or may not ever sound as good.
StephenGiles
Quote from: jdub on April 03, 2009, 10:24:57 AM
If it's for fun - I'm with you!
jdub
R.G., I find myself unworthy of your sage advice, but if you feel so inclined, can you please clarify to this BBD semi-neophyte the difference between cascaded mode and interleaved mode? Am I correct in assuming that they are what they sound like- the former being a one-after-the-other affair, and the latter being a back-and-forth connection?  Are both modes additive in terms of delay time?  Which mode is normally present in flanging applications?  I humbly await your reply...  :icon_wink:
oldschoolanalog
http://www.synthdiy.com/show/?id=881
The datasheet is your friend ;).
Your answers await there...
Mystery lounge. No tables, chairs or waiters here. In fact, we're all quite alone.
jdub
Dig it.  I already have this datasheet (that synthdiy site is a great source), but I think the terminology threw me off.  If I understand correctly, cascading corresponds to serial config, and interleaving corresponds to parallel & differental config... um, right?   :icon_redface:
oldschoolanalog
jdub
