Calculating gain for 4049 inverter stages?
Started by soggybag, April 19, 2009, 02:11:20 AM
soggybag
Is there a quick and dirty calculation for gain on 4049 inverter stages?
Nasse
Yes, took a copypaste from my old post
Here is a formula for calculating the gain of a cmos inverter arranged as inverting amplifier stage:
A = - ((R2/R1)/(1+1/Ao+R2/AoR1))
C1, C2 = DC blocking caps, usually used at input and output circuitry (not included in the formula)
R1 = input resistor
R2 = feedback resistor
Ao = gain of open inverter stage (no negative feedback)
Ao is strongly depending supply voltage, frequecy and tolerances, and varies between manufacturers and individual chips, tolerance may be more than 20%. My data sheet suggests nominal typical values for Ao at different supply voltages, like used to be in the good old days something like 50 at 9 volts, dunno what it is really now
anchovie
I asked on here before about stages that don't have an input resistor and Gez explained that in this case the output impedance of the previous stage forms the input resistance.
Nasse
I think inverter stage does have high input impedance without input resistor... and output impedance too
anchovie
I ended up using the "breadboard and ears" method and didn't take any measurements so I couldn't say what gains I had in the end. Just played around with the "no input resistor" stages until it sounded best!
StephenGiles
"Breadboard and ears" - I love it, works every time!
brett
quick and dirty  formula = feedback resistor divided by input resistor  (e.g. 47k input, 470k feedback, gain = 10)
quick and dirty formula is, by definition, quick and dirty and therefore doesn't always work (e.g. 4.7 k input, 47 k feedback, gain might equal 5.  Why?  Output impedance of previous stage is probably 5k, so *total* input impedance is about 10k, feedback = 47k, gain = 5)
quick and dirty formula (i) works best with large value input resistors (more than 22k),  and (ii) indicates the maximum gain you can get in real life.
just my 2c
Brett Robinson
