simple square wave made simpler clarification
Started by Br4d13y, April 25, 2009, 07:12:41 PM
Br4d13y
freedom is the freedom to say 2+2=4
sean k
The original circuit at circuit snippets has a direct connection between pins 5 and 6.
Monkey see, monkey do.
Http://artyone.bolgtown.co.nz/
R O Tiree
...you fritter and waste the hours in an off-hand way...
Br4d13y
kool
i just finished adding all the parts i have on hand, i jut need to order the stompswitch, 9v plug, tl072 op amp, 2n5088 transistor, pots, 25k trimmer, and a 1n4002 diode.  it is funny, at radioshack they had 1n4001 and 1n4003, but no 1n4002's!!!!!!!!!
soggybag
You can probably substitute 1n4001 for a in4002.
Cliff Schecht
Quote from: soggybag on April 26, 2009, 09:40:52 AM
General rule: You can always substitute a 1N400X series with a different 1N400X part as long as you stay within the absolute recommended power limits. The only disadvantage of the higher number parts (like the 1N4004/4005) is the physically larger size you're dealing with (because of the increased power handling capability). Sonically, you can't tell one from the other.
puretube
With mine, size doesn`t matter... ("UNI"-size from 4001 to 4007...)    :icon_question:
Br4d13y
does poes pot 1 slope the left side of the wave or the right?? i dont have an oscilliscope so i  dont really know
:icon_mrgreen:
