Soldering to jack with contact?
Started by Lameller, December 22, 2020, 03:02:10 AM
Lameller
I want to take the signal from a pcb mounted mono output jack that has 3 pins. It seems to have a contact so that it only outputs sound when a jack is inserted but I would like to take the signal also if a jack is not inserted.
Any help on how to do that?
Best
plug a cable in it, and use a multimeter on continuity to beep the connections when a mono lead is plugged in and when it is not..
make a note of the unplugged and plugged results.....
the lug nearest the socket input is obviously ground, the other 2 are the tip/switch.
Rodgre
It's possible, since this is an output, not the usual power switching switching input jack, that the third lug on the jack is a shorting pin which shorts the tip to ground when nothing is plugged in. Not sure why they would do this, but it's a possibility.
Roger
Lameller
Thanks for the replyes - back to the soldering station for me it is then😀
