any builders/debugging dudes in south yorkshire england?
Started by dimebagslash123, September 09, 2009, 10:38:13 AM
dimebagslash123
end of my tether with this black cat, its a veroboard type from the schematic (done all corrections that anyone can see), but im getting no effect, any body local? im from rotherham/sheffield, give ya a tenner if i can bring it and you tell me whats up with it. more if you teach me how to propper debug?
tiges_ tendres
I used to be near by a few years ago, but I'm not near you now.
Perhaps if no one else can help you, you could try at Bardwells in Sheffield.
http://www.bardwells.co.uk/
Good luck
Try a little tenderness.
The French connection
Maybe you could find someone close to you....
http://platial.com/mapv/DIYstompboxes/598651#
Put your pin on while you're there!
Take a few macro shot and post them in the thread you've already start on your debugging...Maybe we've missed soemthing.
Dan
I know, but the pedal i built does not boost...it just increases volume!
My picture files:
http://www.aronnelson.com/gallery/main.php/v/French+connection/
http://s193.photobucket.com/albums/z4/letournd/Pedal/
In case you can't find anyone close enough, if you don't mind posting it, I'd be happy to have a look at it for you.
alanlan
You'd be better off and get quicker results by posting some detailed pics of both sides and your wiring.  Someone here will be kind enough to inspect your work, I'm sure.
I'm from Lancs, so it's a bit too far, but then again, you wouldn't want to come to Lancs would you now.....we chop up Yorkshire folk and put them in pies served with mushy peas.
tiges_ tendres
Quote from: alanlan on September 09, 2009, 04:08:40 PM
I know a few folks from the Y.R.A* that would definitely like to have a few words regarding the Lancashire pie situation described above.
(*Yorksire.Republican.Army)
dimebagslash123
thanks for the help, ill post some pictures up after dinner, also been out and got some ad100 plug board this morning and another opamp, so if i go back to the drawing board then im not wasting stuff, pics to follow later! thanks again
daverdave
I'm moving to huddersfield on sunday to start uni, you're welcome to bring it down at some point.
dimebagslash123
really? thatd be ace. fed up of the one good sound that i get out of my jcm900 combo lol need some effects, you done many pedals before?
tiges_ tendres
Quote from: daverdave on September 11, 2009, 09:15:19 AM
That's where I went to University!  Are you in halls?  Which one?
markeebee
First stop - put up some pictures. There's more than a good chance that somebody will spot something amiss.
If that doesn't work, you can maybe stick it in the post to me and I can check it over. I'm a long long way from being an expert, but I've done a shedload of debugging on the crock-ups I've built.
PM me if you think that's an option. Only problem is I'm a bit tied up for the nextcouple of weeks due to a bereavement.
