Potentiometer type
Started by stratgear, January 14, 2016, 06:28:21 PM
stratgear
Hi all:
I was wondering why no one uses audio sealed pots, in pedals, like these:
https://www.bourns.com/docs/product-datasheets/91_95.pdf
Is it only a budget matter?
I never saw a pedal with other pots than the usual carbon "Alpha" type ones. Whyyyyyyyyy?  :icon_question:
Thank you
Links aren't working for me but... Race to the bottom with regards to price, Tayda r Us.
dave
stallik
I've got a few high quality ones which I think are referred to as wound pots. Trouble is, they're big, have high turn resistance with a 'lumpy' feel and are expensive. The Alphas are smaller, smooth, feel good when turned, are reasonably priced and readily available in most values so I use them in my pedals.
For guitars however, I want a much lower turn resistance so usually use CTS. Perhaps choosing pots on how they feel is wrong but In my case quality is conformance to requirements. Occasionally I want a very high turn resistance to prevent accidental adjustment. In these cases I pop a small o ring under the knob in contact with the case. That changes the feel totally.
Oh and links don't work for me either
Quote from: stratgear on January 14, 2016, 06:28:21 PM
Hi all:
Yes, largely a budget matter. RS Electronics (as an example) list Bourns sealed pots at £5.57 for cermet and £9+ for conductive plastic. That's at least 4 times what you'd pay for a basic alpha pot.
If you put conductive plastic pots on a four-knob pedal, you'd be looking at £40 before you paid for the enclosure, the jacks, the PCB, or the rest of the stuff. Oftentimes you can put a whole pedal together for that kind of money.
If you're feeling flush and want a luxury pedal, go for it. The Bourns pots are good quality, last a long while and won't let beer in. Maybe they're worth it. Some of the top-end modular synth manufacturers use them for longevity.
HTH,
Tom
samhay
I like Bourns GTR pots for guitar/bass duties - have never been able to justify the price of the sealed pots.
The size would make them impractical for many pedal builds.
http://www.farnell.com/datasheets/1771756.pdf
What's the point of using sealed pots in a pedal? Or is this more about overall quality rather than the fact they're sealed.
stratgear
Quote from: slacker on January 15, 2016, 11:54:18 AM
What's the point on using sealed pots in an amp or preamp that won't be exposed to such an heavy use and environment as a pedal usually does?...I'm still curious... :icon_confused:
I don't know, hopefully someone can help us out.
If you look just at the fact they're sealed, the ones you provided a link to are only IP40 rated, so they don't keep out dust or beer, so in a pedal I don't see any advantage over standard pots. https://en.wikipedia.org/wiki/IP_Code They do make IP67 rated ones but I dread to think how much they cost.
The other specs don't seem significantly better than standard Alpha or other similar quality pots.
