2 in 1 amp
Started by darrylportelli, July 04, 2009, 11:19:08 AM
darrylportelli
Hey
My dad plays bass and decided to build a tube amp for bass. since I play guitar I figured can we make a poweramp and 2 preamps one for bass and one for guitar and then switch between one another.Then I use a guitar cab and my dad uses a bass cab. Would it be good to share the power amp or do bass and guitar need different poweramps(i dont think so but then again im not an electrical engineer) ??
BAARON
Or you could just build something like a Fender Bassman clone, such as an AC568 model where you have a "bass" and a "normal" channel that each have their EQ and volume controls and can be used simultaneously...
http://www.schematicheaven.com/fender.htm you can find the schematic (and many more) here.
Not that there aren't people here who can answer this question, but you might want to ask amp questions at a DIY amp building forum instead, because they might be more helpful with the actual building process.  I like AX84.com myself.
B. Aaron Ennis
If somebody makes a mistake, help them understand what went wrong.  Show them how to do it right.  Be helpful.  Don't just say "you're wrong, moron."
darrylportelli
Ok but you know I found this forum and all the chaps here are very helpful!!! I kinda got hooked posting on this forum these couple of days!!!!
Ripthorn
I would say just remember that the requirements for output transformer, power output, etc. are very different for guitar and bass.  If you play bass, you will need a bigger output transformer and more power to get the same volume levels for guitar.  It can totally be done, but you have to pay attention to things like transformer frequency response and how much juice your power transformer will supply.
Exact science is not an exact science - Nikola Tesla in The Prestige
https://scientificguitarist.wixsite.com/home
