Seeking brightness mod for BYOC ESV Fuzz
Started by GuitarPlayer, May 17, 2009, 10:47:36 PM
GuitarPlayer
Hi, I recently completed a BYOC ESV Fuzz and would like to modify it to get more treble. Can someone suggest a value change/mod for more brightness?
Thanks,
Jake
The schematic:
Derringer
if you replace C3 with something less than 0.1UF, I'd start with o.o1uF, you'll get less bass
if you're not diming the volume, you can also solder a 100 - 1000pf cap from lug 2 to lug 3 of the volume pot
100 would give the least amount of treble  ... greater capacitance will give more
Gus
#2
http://www.buildyourownclone.com/board/
or google or look at links above
Brit face
chi_boy
Wouldn't C1 be the place to start?
The Easy Face adds the blend that changes the value of that input cap.  It acts kind of like a tone control and really brightens up the sound.  I'm not one of the pro's, but I would suggest researching changing that cap.  Should take out some bass and get some of the treble back, just like on the Easy Face.
Cheers.
"Great minds discuss ideas, average minds discuss events, small minds discuss people." — Admiral Hyman G. Rickover - 1900-1986
The Leftover PCB Page
GuitarPlayer
#4
Thanks chi_boy and Derringer. I'll give those a try.
Quote from: Gus on May 17, 2009, 11:05:54 PM
Brit face
Thanks Gus, I posted the same question there yesterday (http://www.buildyourownclone.com/board/viewtopic.php?f=23&t=18095) but no response. This board has a lot of activity so I decided to give it a try :)
Gus
GuitarPlayer
Quote from: Gus on May 18, 2009, 10:43:31 AM
Did you google "brit face fuzz' yet?
Yes, I got 314,000 hits  :icon_biggrin:
I'm going to try the cap changes suggested above for now. Thanks Gus!
GuitarPlayer
Follow-up:
Quote from: Derringer on May 17, 2009, 10:55:56 PM
Hey Derringer,
This was going to be the quickest and easiest mod, so I soldered a 100pf cap to lugs 2 & 3 as you suggested.
SUCCESS! That's all of the increase in treble, decrease in bass that I need for this pedal. It was just a little too muddy before and it is perfect for my tastes now. If I need any more brightness I can get it with EQ on the amp.
Thanks for the suggestion. I learned something more here!  :icon_biggrin:
Cheers,
Jake
chi_boy
Jake,
Glad you found what you were looking for!  I may try this myself.
I have a question though. Is it really LESS bass, or just a better balance between bass and treble. I thought that mod would just let more treble out. Don't get me wrong, I'm not being picky, just want to understand what to expect.
Cheers,
George
GuitarPlayer
^^^^^^^ To me it sounds like a little of both; less bass more treble. But technically the cap filters out frequencies, right? So it must be filtering out lower frequencies?
One of the gurus will probably weigh in with the correct answer.  :icon_biggrin:
The French connection
Put a socket and try differrent value...fix the one that suit your taste!
Dan
I know, but the pedal i built does not boost...it just increases volume!
My picture files:
http://www.aronnelson.com/gallery/main.php/v/French+connection/
http://s193.photobucket.com/albums/z4/letournd/Pedal/
Derringer
Quote from: GuitarPlayer on May 19, 2009, 04:34:15 PM
the cap in question is allowing the treble frequencies to pass "more easily" tot he signal
The high frequencies that the 100pf cap is allowing to flow are bypassing the resistance supplied by the pot.
