post your favorite tone control!
Started by ninjaaron, May 16, 2009, 06:19:03 PM
ninjaaron
I'm building a dirt box and I'm looking for ideas to steal. ;D
(but seriously, I am)
Andi
Tweaked BMP. I forget the values but it ends up with a narrowish notch in the middle.
ninjaaron
Quote from: Andi on May 16, 2009, 06:49:16 PM
I'm thinking about a BMP derivation. I kinda want it to have a slight mid boost no matter when I set it, however, so I will have to tinker.
I'm also considering ripping the tone stack off the DLS and seeing how that works
Derringer
#3
here's how you can boost the BMP tonestack mids
http://www.muzique.com/lab/tone3.htm
Thank you Mr. Orman wherever you are :-X
you might like a Baxandall design too if you're looking for mid-boost ability
My favorite tone control .. the SWTC
John Lyons
+1 forMark Hammer's Stupidly Wonderful Tone Control (SWTC)
Basically just a high-pass filter but with very little volume interaction.
John
Basic Audio Pedals
www.basicaudio.net/
Vitrolin
have anyone tried the AMZs SWFTC2
http://www.muzique.com/lab/swtc.htm
well i imagine that in overdrive/distortion/fuzz circuits the treble boost feature would be quite useless/anoying due to the harmonics multiplication.
Derringer
yup ... I've used it (SWTC2). It does EXACTLY what it's designed to do ... and does it well.
mth5044
SWTC rules. You could give the tonemender a whirl too, then play around with some values.
ninjaaron
I'm gonna go ahead and bump this. Great responces so far. I'm looking into all of these. Great thread, if I do say so myself.  :icon_lol:
I don't think there is any "best" tone controls, and even mere "favourites" will vary depending on what they are being used for.  The aforementioned SWTC is very useful for shaving off some of the hair of a distorted sound so that it is reasonably well-matched to the bypass tone, with respect to treble.  But it is not intended to provide broad tonal change of the sort that might constitute a "personality change".  There, the BMP control, and all its variants, provide something more drastic.   Also worth looking into is the variable scoop, based on the midscoop filter found on the Superfuzz and assorted Shin-Ei distortions.  Finally, the "Contour" control, found in some Marshall products is also a very flexible control producing lots of different "characters".
Where the SWTC can be configured to eat up very little signal, unfortunately the other types tend to be signal-gobblers, bleeding much off to ground to do what they do.  Happily, that can be compensated for by either starting out with a hot signal, or by adding a gain recovery stage (as the BMP does).  So, workable, but you have to plan for it.
oddist
Here's one I've been fooling around with.  Works nice with light to medium overdrives.
At one end, the tone control passes a LPF shelving type filter, which is nice because it keeps a fair amount of high end
will cutting out some fizziness.  The pot itself is part of a much lower tuned LPF, and acts to pan between both.
See what you think.
punkin
Ernie Ball Music Man - JPM, THD Univalve, Grace Big Daddy, PepperShredder, BSIAB2, FireFly Amplifier.
rnfr
i really like the tone control in this circuit.  i lifted it from the supro thunderbolt.  it goes from nice full midrange, to very thin, to very fat.  a lot of versatility in one knob.
ninjaaron
Quote from: rnfr on May 19, 2009, 12:46:23 AM
What circuit?
blueduck577
i was thinking about the big muff this afternoon. suppose we took a big muff tone stack, modified it for flat mids, but then stuck a boss mt-2 mid control after it?  i think it might be something worth looking into, being able to scoop/boost the mids exactly how much you want, at whatever frequency you want.
Gila_Crisis
oncee i built a OLC  Orange Peel, which features this tone control:
i like how it works
ayayay!
Quote from: Gila_Crisis on May 19, 2009, 06:48:48 AM
i like how it works
That looks very interesting indeed.  But does it make the two tone knobs somewhat interactive when one or the other of the knobs is at it's extreme left or right?
The people who work for a living are now outnumbered by those who vote for a living.
Earthscum
Since this thread is going right now, any suggestions for a tone control to go between a first boost/gain stage and the next successive stages? I tried SWTC and SWTC2 straight off my bass, and it sucks too much juice and really dulls the entire circuit (same with my guitfiddle... tuned to Dflat). I also tried them after a boost/gain stage, and basically it was like an entirely different control... it was like all of the sweep was gone. All it did was simply DULL the highs.
Is there a fairly simple tone control that will do a notch boost/cut, notch frequency and width? That would be the best for me... I'm trying to basically get certain tones to clip harder than others, and am probably gonna use BMP or SWTC at the end for tone recovery or suppression.
I dig the SWTC's. They are nice and simple and don't require as much volume adjustment.
ninjaaron
Ok, thanks for all the replies. I think the SWTC will probably be best for what I'm doing at the moment. I'm still tinkering with bass controls and haven't found a great solution yet, but I'll come up with something... eventually...
