XP 300 Space Station - true bypass?
Started by Jackie Treehorn, May 22, 2009, 12:09:43 PM
Jackie Treehorn
Hello,
Does anyone know a clever way to do a true bypass on these without drilling and installing another footswitch?  I guess I'm looking for a way to use the existing switch to trip a relay.
Oh, and here's a clip of a bunch of xp 300 sounds!  http://www.theinside.net/Space Station 2.mp3
iaresee
Why not just build an external bypass box? Simple. Keeps the space station stock.
FuzzAldrin
yep, I use a small TB box with mine. easiest way to do it.
Processaurus
A solution the crummy bypass, I stuck a dual attenuator pot on the plastic side under the lip, and had cut off the shaft and slotted the end so it is discrete.
http://www.diystompboxes.com/smfforum/index.php?topic=58144.msg484181#msg484181
Processaurus
Schematic for the xp series pedals, you can see the FET bypass on page 2:
http://ca.geocities.com/lwperreault/DigitechXP100.pdf
