Ibanez CSL and other choruses
Started by jrc4558, May 29, 2009, 10:03:46 PM
jrc4558
Hi all!
I am trying to modify my master series Ibanez CSL - http://filters.muziq.be/model/ibanez/master/csl
While there's no schematic for this pedal available online for free (and I'm still not as desperate to buy one), I'm referencing from this one: http://www.schematicheaven.com/effects/ibanez_sc10_superstereochorus.pdf
When effect is on, there's a considerable volume boost. I am trying to remedy this.
First I looked at the R20-R21 voltage divider (just before CP2). I increased the value of R20 and it did fix the volume boost problem, but also reduced the amount of chorusing to practically none. Then I realized why, but that's besides the point.
I would like to ask, is there a known solution to this? has anyone successfully level out the volume of effect on end effect off on these shoruses without loosing the amount of chorusing?
Also - which capacitor colrols the depth of modulation on the MN3101? Is it the C27?
Thank you very much!
Thomeeque
Quote from: Constantin Necrasov on May 29, 2009, 10:03:46 PM
Hi all!
Hi!
Wet signal path can be attenuated relatively simply by increasing value of R23/R30 resistors. Dry signal path must remain untouched in bypass mode, therefor it's bit more complicated - IMO easiest way would be to interrupt path from IC2 pin 7 to junction of C18 and C20 and put some kind of controlled attenuation there, e.g.:
(where Qx gate would be controlled by same signal as Q9 and Rx2 would be adjusted to desired attenuation - Rx1 and Rx2 could be replaced by one trimpot as well).
Or you may consider true-bypassing (overal volume of effect could be adjusted by altering R32, R29, R30 and R31 (or R32 or R33 :)))..
Depth of modulation (if you are talking about depth of sweep) is not controlled by any capacitor, but maybe I just don't understand question - what is it you want to achieve here?
T.
Do you have a technical question? Please don't send private messages, use the FORUM!
