Please Help me on Rebote 2.5
Started by urbanspaceman, June 06, 2009, 11:08:45 AM
urbanspaceman
Hello fellows!
i'm francesco from italy and this is my first post.
I have some trouble with Rebote 2.5 delay.
I etched the pcb, mounted all components with minor changes on the value.
I do a bit of confusion in identifying capacitors and maybe my problem is this.
out of circuit only hear the sound clean and not delay ...
i post the IC values
battery 9.5 volts
PT2399
1--  4,9
2--  2,44
3--  0
4--  0
5--  4,9
6--  2,45
7--  0
8--  0
9--  2,45
10--  2,45
11--  2,45
12--  2,45
13--  2,45
14--  2,45
15--  2,45
16--  2,45
17--  2,45
18--  2,45
IC2 tl072
1-- 4,63
2-- 4,63
3-- 4,60
4-- 0
5-- 3,71
6-- 4,62
7-- 4,62
8-- 9,28
this is a shot from my finished pcb
see the value of capacitors...
can i have a little help from you?
sorry for bad english!
arma61
Ciao Armando here also from Italy!
at a first glance I can see most of the yellow and white caps are wrong/swapped, though I don't know how much they can prevent the effect from working.
taking into account that your caps are the same as the one I have on a working Rebote and according to this "table"
1n=0.001
10n = 0.01
100n=0.1
you should change
3 white top = you have 10n should be 100n
3 yellow bottom= you have 100n should be 10n
1 yellow beside PT=you have 100n should be 1n
1 white bottom = you have 10n should be 100n
1 yellow close to TL = you have 100n should be 10n
ok check again yourself what above just to be sure as my eyes got crossed now  :D!!!
The table is right I took it from here : http://www.justradios.com/uFnFpF.html
keep it on hand, it's very usefull.
Cheers m8
Armando
"it's a matter of objectives. If you don't know where you want to go, any direction is about as good as any other." R.G. Keen
urbanspaceman
Ciao Armando, ti ringrazio :-)
Faccio le modifiche, se hai voglia e se non lo conosci visita noisecollective.net il mio sito dedicato al diy!
Hello Armando, thank you :-)
I try to make the changes, if you want and if you don't know visit noisecollective.net my site dedicated to diy!
urbanspaceman
urbanspaceman
#4
i don't have a 1n capacitor... i have many ceramic (orange disc) capacitor... is the same?
What value should I put?
arma61
in most case,I think, the value is most importart, so either film or ceramic should be fine, so in this case you need a 1000pF cap
Ciao
Renegadrian
