Artistic Painting On PedalPartsPlus pre-painted enclosures
Started by studiostud, June 09, 2009, 05:05:28 PM
studiostud
I would like to do some artistic painting on some enclosures that I purchased pre-painted from PPP.  From my email correspondence, I learned that they use a polyester based power coat paint and a poly based clear coat.  I've had my share of mishaps with using different types of paints and clear coats and getting cracking/blistering/etc, so I'm wondering what type(s) of paint would be safe to use on this type of surface?
Builds Completed: Big Muff. Fuzz Face. Tube Screamer. Rat. Crash Sync. Harmonic Jerkulator. 6-band EQ. Rebote 2.5. Tremulus Lune. Small Stone. Small Clone. Microamp. LPB-2. Green Ringer. Red Ranger. Orange Squeezer. SansAmp. MXR Headphone Amp. Bass Fuzz.
BAARON
Acrylic paint should probably be fine, but I can't guarantee it'll stick in the long run.  If you scuff up the surface a bit beforehand (perhaps with a Scotchbrite pad), it might help adhesion.
B. Aaron Ennis
If somebody makes a mistake, help them understand what went wrong.  Show them how to do it right.  Be helpful.  Don't just say "you're wrong, moron."
MikeH
I've used Testors and Sharpie paint markers- both worked fine
studiostud
ok cool.  I know this may sound silly, but what about spray paints.  I don't want to spray the whole enclosure.  Just parts of it.  Enamel and Lacquer both ok?  What about clear coating to make it last longer?
MikeH
Every clear coat I've tried has worked fine with powdercoat, which leads me to believe that spray paints should be fine too.  Whether the clearcoat plays nicely with the spray paint is a different story all together.
studiostud
ok sweet.  yeah, what I'm looking at doing is getting the enclosures painted in bubble gum pink and then taping off certain sections with painters tape and using a white spray paint to paint on white candy stripes.  So I guess the key is just to keep it all unified in which ever I use whether it's lacquer or enamel.
