2 switchable effects loops in a stop box
Started by doug0147, July 02, 2009, 02:27:12 PM
doug0147
I need to make a pedal with 2 effects loops that can be switched on or bypassed. I need the first loop to feed into the second loop. It seems like all I really need to do is wire up two 3pdt switches, some jacks, and led's. I don't think I even need any kind of circuit here. Does that make sense?
The French connection
I know, but the pedal i built does not boost...it just increases volume!
My picture files:
http://www.aronnelson.com/gallery/main.php/v/French+connection/
http://s193.photobucket.com/albums/z4/letournd/Pedal/
ayayay!
#2
I'm not sure if you mean something like this:  http://www.beavisaudio.com/techpages/PedalHacker/OrderSwitcher.htm
...or just building a pedal w/ 2 bypass loops in series?
The people who work for a living are now outnumbered by those who vote for a living.
MikeH
1- Find a layout for a single true bypass loop
2- Make a copy and put the 2 side by side
3- Remove the 'out' jack from the first one and the 'in' jack from the second.
4- Draw a line between where the jacks used to be
done
LEROY
I used this and just hacked off the bits I didn't need and it worked perfectly!
The final product...
I run one loop for clean stuff like comp, chorus, phase, auto wah and one loop for dirt like uni-vide, fuzz, wah... I put the delay after so I can switch channels and still have the delay trails......
doug0147
Thanks guys, I knew it couldn't be that hard. :)
