108,000 degrees... of phase shift
Started by earthtonesaudio, June 22, 2009, 01:03:37 PM
earthtonesaudio
I want to convert an audio signal to an AM signal, phase-delay the HF sine wave, and vary the carrier frequency to get adjustable time delay.  Don't ask me why.
For a 20kHz carrier, a maximum of 15ms delay requires 108000 degrees of phase shift.  All-pass filtering is the logical choice, for its constant amplitude-per-frequency output.
Anyone know of a way to fit 600 all-pass stages into a stompbox?
gena_p1
  Why  :icon_razz:?
  ...lol...sorry, had to ask  ;D ;)!
earthtonesaudio
Alright, since you asked for it...  ;)
The BBD approach has been done a bazillion times already.  I want to try a different approach, not because I think it would be easier (it won't), and not because I think it will be better (who knows?), but simply because it's different, and I don't think anyone's tried, at least not since BBDs were invented.
Or another, less annoying reason: I think it's possible for this modulation scheme to produce less audible noise than a BBD of comparable delay.
gena_p1
600 FETs + 600 Trim Pots + Cooler and you - Columb :)
earthtonesaudio
#5
Perhaps some other filter types could be more efficient with the space...
http://www.filter-solutions.com/description.htg/chevy1bstop.gif
Notice the group delay (pink) varies logarithmically from 3-6MHz (a factor of 2, nice!) while the amplitude is essentially flat.
I wonder if you could achieve a similar response using a long chain of (occasionally buffered) ceramic resonators... Cheap and small...
[edit] Also, the highpass response: http://www.filter-solutions.com/description.htg/chevy2hipas.gif
