"Caps in series" switching
Started by jdub, June 23, 2009, 10:58:36 AM
jdub
Just a quick question for those who know: how exactly does the "caps in series" cap-switching method  (a la John Hollis' Zombie Chorus as mentioned by Mark Hammer (http://www.diystompboxes.com/smfforum/index.php?topic=54829.0) and illustrated in this post: http://www.diystompboxes.com/smfforum/index.php?topic=56671.msg438331#msg438331) work electronically?  I don't quite get the idea of "shunting" one of the caps.  Does this simply mean that when the switch is open the current flows through the switchable cap (since it can't go through the switch) and when the switch is closed the current follows the path of least resistance (the wires connected to the switch) and essentially "bypasses" the cap?  Am I way off base here?
A boy has never wept nor dashed a thousand kim
earthtonesaudio
Not to worry, you're 100% correct.
A cap is like a frequency-dependent resistor.  A piece of wire is a zero-ohm frequency-INdependent resistor.  When the signal has a "choice" of the two, for all intents and purposes, the cap doesn't exist.
So, having two caps in series, and using a toggle to shunt one or the other essentially dictates which cap the signal HAS to pass through.
jdub
Thanks guys! I think I'm starting to get the hang of this stuff!
