Superfluous Superfuzz components?
Started by Derringer, June 25, 2009, 05:26:05 PM
Derringer
1. What's the purpose of the elecytrolytic that comes after the diodes?
   I took it out and seems to work fine without it.
2. I like the sound going through the T-Notch with a pot between the cap
    and ground (thank you Mr. Hammer) so I just chopped out the 47K
    and 10K that come right before it. I tried it with just a 47K to ground
    and without anything to ground there. Didn't make a difference either way.
    Any reason to have a resistor to ground there?
3. I ditched the 100K on the output to. It didn't sound different without it.
   Any good reason to leave it there?
drewl
#1- Stability for crappy leaky 60's germanium diodes?
Don't know.
Hey while we're here, I wired up mine and stuck in some generic 2N2222's in the sockets and it looks great on a scope.
The enclosure should be dry by tomorrow.
Anyway, I noticed that the 10k bias can remove the octaves, anybody make that swithcable so the octave is switchable?
DiscoVlad
Quote from: Derringer on June 25, 2009, 05:26:05 PM
DC blocking for the filter section? Though the output transistor stage has a coupling capacitor for this reason anyway.
Having a look at it in spice, removing that capacitor only slightly alters the frequency response below 2Hz so the effect it has is inaudible anyway.
The 47 + 10k resistor are a voltage divider, which attenuates the unfiltered signal to be close (not in the ones I've built?) in volume to that of the filtered (1kHz notch) signal.
If you're hard-wiring the filter so that it's always on, these two resistors aren't needed.
That's a pull-down resistor so that the output doesn't float when the effect is bypassed.
Its purpose is like an input pull-down, to lessen/stop the "pop" which happens when you switch the pedal in and out.
So, it's not strictly necessary, but having one there is in most cases, a good practice.
DiscoVlad
Quote from: drewl on June 25, 2009, 10:28:08 PM
Don't know.
Try changing the 22k resistors in the octave section to 15k, or 18k. That should be enough to compensate for the 2 x 5k of the bias trimpot.
Derringer
#4
awesome, thanks folks!
and yeah, I do have a 10K pot between the 22K resistors on the octave amplifying transistors
I had it on my scope today and no matter where I turned that pot to, the octave was still there. It just seems to adjust the amplitude, and to a lesser degree the shape, of the octaves so that you can better match them.
The expander pot however can dial out the octave ... at least with a sin wave
I'd imagine thought that you'd have to beef up the final gain stage to run the effect at a suitable level with the expander backed off to where the octave is absent
   It looks like there's a 10uf / 5v cap sitting right next to 9v supply, I'd feel safer with a 16v rated cap there.
Derringer
but then you'll lose the inherent "exploding capacitor" sound
heh  I never noticed that it was only 5V .... good eye.
