swell device?
Started by Br4d13y, May 14, 2009, 12:37:41 AM
DWBH
Oh, the pick is attached to the circuit? Got it then.
IMO, it's a much better design than Boss's Slow Gear.
Derringer
oh yeah ... definitely
the trigger with the pick will be sooooo much more accurate
solderman
#42
Report from the Bread Board
Fired it up and, after the usual "where did I go wrong" debugging the thing works like a charm. Really good swell and has quite a broad settings spectra for attack an decade so it's really flexible. Thank's to the "pick to ground" setup the precision is 100% all the time. The only ting is that when you hammer on or pull off you won't get a swell unless you ground your finger tips as well  ;D
Best swell circut I've tested yet.
http://www.dirk-hendrik.com/temp/dod_fx15.pdf
http://filters.muziq.be/model/dod/fx/fx15
The only bad sounding stomp box is an unbuilt stomp box. ;-)
//Take Care and build with passion
www.soldersound.com
xSolderman@soldersound.com (exlude x to mail)
DWBH
I've been trying to find one of these on ebay, but I never saw not even one popping up.
edd29
#44
thanks alot guys! i hope you really like it .
pick is connected in between 100k and 220k. and the strings is already
connected to the ground.
rousejeremy
Quote from: edd29 on June 30, 2009, 05:23:11 PM
Fantastic idea.
Consistency is a worthy adversary
www.jeremyrouse.weebly.com
edd29
Quote from: rousejeremy on June 30, 2009, 05:43:11 PM
Fantastic idea.
thanks man!
solderman
Hi All
Here's the "That's Swell" DOD FX 15 Clone.
I Just love the conductive pick settup. Thank's for that ideé.  Here is the projectfile and the PCB transfer if some one wants to build it. It's sized for fitting in a 1950A enclosure but can of cause be put in whatewer box.
It works verry well and the only change I'v made is to put a 1M pull down resistor before the first cap at IN
http://solderman.fatabur.se/swell/hat's%20Swell%20Project%20File.pdf
http://solderman.fatabur.se/swell/hat's Swell Project PCB.pdf
www.soldersound.com
edd29
#48
Quote from: solderman on July 02, 2009, 01:58:33 AM
Hi All
you so quick making this layout.THANKS!
