Transformer Question
Started by Giglawyer, November 28, 2018, 07:20:06 PM
Giglawyer
I am building a Laika Fuzz from Dead End FX this winter.  It calls for a Xicon 42TL019-RC transformer, which appears to be hard (but not impossible) to get.  It would be much easier to get a 42TL021-RC transformer, which many suppliers seem to have in stock.  The key difference in the two is the primary impedence:  10kOhms for the 42TL019 and 4kOhms for the 42TL021.
Will the 42TL021 work, or do I need the 42TL019?
Check out my builds - http://www.giglawyer.com
tonyharker
It helps when asking a question like this to add the schematic.
antonis
Especially in case of primary winding considered as Collector load...
tonyharker
It appears that the transformer is used as an inductor not as a transformer.
So the inductance of the transformer primary is the important parameter not the transfer impedance which assumes a load on the secondary.
It's actually acting as a pickup load, so you can use this pedal wherever you want in signal chain.
Any 10k impedance inductor will probably work. You can try with any 10k transformer, or you can make an inductor yourself.
There is a transformer table on this page https://abra-electronics.com/power-supplies-transformers-adapters/audio-transformers/miniature-audio-transformers-75mw-max-output/42tl019-miniature-audio-transformers-75mw-max-output-42tl019.html showing that those 10k little transformers have primary resistance of 450-900 ohms, so you may try to use an old modem or similar transformer and try it out.
Giglawyer
Thanks for the answers so far.
Here is the schematic.
Giglawyer
Quote from: rankot on November 29, 2018, 09:10:58 AM
Thanks for your input.
Notice the 42TL021 is 4k impedance and only 148 ohms DC.  Both these suggest the winding has less turns. So inductance is lower and it probably won't work as intended.
There's more info on this here https://www.diystompboxes.com/smfforum/index.php?topic=119700.0, so I suggest to move the talk about this transformer to that thread.
