Reason the 4049 based distortions use high value caps?
Started by tackleberry, July 08, 2009, 05:27:51 PM
tackleberry
All the 4049 based distortions I see (andertons tube sound fuzz, insanity box, DoubleD) have a 4.7uf to 10uf electrolytic after the hex inverters. Whereas most other pedals will use something like a .1uf or 1uf cap between stages. Is it something inherent with 4049s that you need a polarized cap or a large value 4.7/10uf? Or can regular 1uf films be put there with no problems?
dschwartz
i´d say that´s only a design chioce..AFAIK, inverters have high input Z, but also high output Z, maybe that´s why big caps are used..but i have used smaller caps (even 5n) between inverter stages without trouble
Tubes are overrated!!
http://www.simplifieramp.com
valdiorn
Quote from: dschwartz on July 08, 2009, 06:13:02 PM
Digital logic usually has high input impedance, but that's because they operate at either end of the spectrum, 5V or 0V, and since a gate has 2 FETS (CMOS = complementary MOS), one of them is always in cutoff, so very little current flows. However, using a 4049 as an amplifier, you are running it in the active region, and there is actually a LOT of current running through there. Many people have noted that the chips get flaming hot after a while, and that 4049's are not the best idea for battery-powered pedals...
