dod fx25 broken switch
Started by bagudan, July 09, 2009, 06:33:32 PM
bagudan
Hi. i have an old envelope filter, dod fx25. It actually sounds pretty good, but as in many other dod pedals from that time, the switch is broken. Does anyone know of a replacement idea...is it just a momentary switch that does some sort of electronic switching?
The switch itself is a little flat/round switch, mounted on its own little board.
edvard
Yes, it's just a momentary switch, percussion type.
Underneath the plastic button is a little metal dome that 'pops' down and makes contact with a metal layer underneath it.
I replaced more of those than I care to think about...
Any momentary tactile switch of similar size and shape should do, if you're trying to preserve the pedal.
One time I re-used a DOD case (the electronics went south and I had better plans...) and simply replaced the footpad with a permanent piece of plastic and mounted a nice big metal momentary spst on it.
Worked a charm and will probably last as long as the rest of the pedal.
bagudan
oh yes....just removed the plastic, and installed momentary...and it works...
thanks
zombiwoof
Just for everyone's knowledge, DOD/Digitech still sell the two types of switches those old pedals used on their website (last time I looked).  They are also available on Ebay at slightly higher prices.
Al
