the English Channel.
Started by darrylportelli, July 19, 2009, 02:47:26 AM
darrylportelli
Hey. My friend built the English channel from runoffgroove : http://www.runoffgroove.com/englishchannel.html and It is not working. I asked if I can debug it. problem is that it has a very fuzzy sound and he soldered the jfets directly not on sockets so Im gona try replacing them. Do you think that the jfets are the problem here??
kurtlives
Check the voltage on the drain's, should be 4.5V.
My DIY site:
www.pdfelectronics.com
Paul Marossy
Quote from: kurtlives on July 19, 2009, 08:50:46 AM
+1. However, Q3 should be 9V since it's connected directly to the 9V power supply.
Joe
That's a pretty clever name for that circuit.
Paul Marossy
Quote from: Joe on July 19, 2009, 10:33:16 PM
I thought so, too.
doitle
I'd love to try to build one of these as I think they sound really neat but it's way more complicated than I'd be capable of at this point in time... :/
Has anyone used a PCB from OLC: http://olcircuits.com/olc_englishchannel.html to build this? 15$ Doesn't seem so bad... I'm sure I could build it on a PCB just not breadboard/protoboard...
darrylportelli
15$ sounds like a rip off when you can make your own for around 2 $ or less.The only thing you need is FeCl3(ferric chloride etchant) a blank pcb and a laser copier(go to the local copy shop) then check out the toner transfer method to do pcbs...works like a charm every time.
Paul Marossy
Quote from: doitle on July 20, 2009, 03:08:51 AM
It's very simple if you follow the perfboard layout at ROG. The most difficult part would be wiring the pots so they work correctly. I still occassionally mess those up even after all these years.
I agree that the RTS PCB would be easier still.
DougH
Quote from: darrylportelli on July 20, 2009, 07:47:11 AM
$15 is pretty much the going rate for a fabbed one-off PCB board someone else did the artwork for.
Paul Marossy
Quote from: DougH on July 20, 2009, 12:43:47 PM
I don't think that is a bad price considering the costs to do small PCB production runs.
DougH
Nope, not at all. It's well worth it to me. Doing a one-off PCB is way more of a PITA than it is worth. I can usually whip something up on perf board in about a tenth of the time & hassle.
