Need more height in an enclosure...
Started by Belt, August 05, 2009, 08:43:45 AM
Belt
I need a tad bit more space in the box depthwise.  Any ideas / solutions other than the plexiglass spacer.  I've seen that one and like it.  But I think I'm looking for something else.
Thanks Y'all
All for Him
jacobyjd
Depending on what tools you have on hand, you could make a wooden spacer...if you need a quick fix, cut up a pen or something to use as suspension posts.
ayayay!
Take your backplate screw to the hardware store.  Match the thread with a longer screw.  Then get some platic tubing or even a straw...some kind of hollow cylinder... to use as a standoff.  Cut 4 identical lengths, and place the standoff between the plate & enclosure.
The people who work for a living are now outnumbered by those who vote for a living.
Belt
I'm thinking about a permanent solution.  I've got some 1290's that I just need to get about 1/8th to 3/16th's more out of.
Wood might be better than plexi
I don't know that an air gap would be desired, but the plastic tubing works great for supporting PCB's
All for Him
markeebee
I cut up an old mouse mat to make a sort of gasket between the backplate and the box.  You use a double or triple layer to increase the depth.  Added bonus: provides some shock absorbtion for the knees and ankles when stomping!!
Also, if you cut it to shape you use it to retain a battery or even a PCB if you were feeling adventurous.
Belt
A combo of a mouse pad with spacers to hold the height is a solution for sure for me.  As far as my pedals, I like uniqueness.  But beauty is in the eye of the beholder.
I think the best full time solution is plexi though.  I don't think I'd add the LED for light up.  But it seems that'd be a permanent solution.
I'm coming up with a JB Weld solution....
mua ha ha
All for Him
Belt
disregard the JB Weld thought
spacers for today
plexi for tomorrow
thanks for the input
All for Him
jacobyjd
Belt
I'll have some pics eventually
I'll have some clips eventually
I'll have some vids eventually
I'm not the most technologically advanced today
Pics are gonna be up soon
;D
All for Him
Al Heeley
+1 for the illuminated plexi spacer - both functional, clever and beautiful, like my ideal woman to be honest. :icon_lol:
And you can screw into it quite easily too.
Belt
All for Him
trixdropd
Where can one buy an illuminated spacer?
tiges_ tendres
Quote from: trixdropd on August 05, 2009, 06:37:45 PM
You have to make one.  Plexi glass cut to the correct size will do the job.  Search for the tutorial.
Try a little tenderness.
trixdropd
Quote from: tiges_ tendres on August 05, 2009, 06:43:25 PM
Ah, I thought that maybe there was one available that had the led built in already somewhere. Thanks!
Belt
I've seen pics of a few pedals with the plexiglass.
It looks neat
All for Him
