Check out my Brian May treble booster PCB!
Started by rockgardenlove, April 12, 2007, 06:07:54 PM
rockgardenlove
How's it look to you guys?  Schematic here:
tcobretti
C2 is not right.  I believe it is supposed to be the 47uf electro that goes from the emitter to ground.
C3's value is unlabeled on the schem and the layout.
Otherwise, nice job.  It is certainly aesthetically pleasing.
rockgardenlove
Oh, oops.  I messed up on the schematic there.
The jumper on the schematic between the emitter and the base should be that 1n capacitor.
I just forgot the emitter bypass 47uf.
Will update.
rockgardenlove
#3
I wish the edit function didn't time out...
How's that look?
tcobretti
Ronsonic
Cool circuit and a great sound. That variations on that design have been pretty good to me. Change about five things and you've got an Electric Guru. So don't muscle in on my mojo, punk. :icon_biggrin:
There's a nice balance of components and values to work from. there. Enjoy.
Ron
http://ronbalesfx.blogspot.com
My Blog of FX, Gear and Amp Services and DIY Info
Renegadrian
Christian G. corrected layout was hosted at imageshak, but it is no more available...
So I took the time to correct it myself and put it in the gallery...Hope it helps...
