Hole Plugs for unused switch or LED holes
Started by tjmicsak, August 08, 2009, 05:06:02 PM
tjmicsak
is there any source for snap-in metal hole plugs or even plastic flush snap-in hole plugs for using boxes with excess holes not used?
bluesdevil
I noticed some hole plugs in the new Mouser catalog..... try a search on their site.
"I like the box caps because when I'm done populating the board it looks like a little city....and I'm the Mayor!" - armdnrdy
Ripthorn
Do you want to be able to use these holes later?  I have used JBweld and bondo also works for a permanent solution.
Exact science is not an exact science - Nikola Tesla in The Prestige
https://scientificguitarist.wixsite.com/home
jimbeaux
I use the ones shown on the bottom of the page.
They're easy enough to pop out & re-use.
http://mouser.com/catalog/catalogUSD/639/1855.pdf
Roland
I like to use "Quicksteel"...just chop off a little piece...knead it till it gets hot ..fill the hole ..flatten it..you can even add water to make a neater smooth hole plug. You can tap it ..drill it etc.....cures real fast.
Here is how it looks:
http://www.aerostich.com/quicksteel-epoxy-putty.html
Only one problem with it...you must use it all within 6 mos...bad shelf life . But when you use it 'll last forever though.
GibsonGM
"Barbed" auto panel fasteners work great, they are plastic and you could paint them....come in many sizes, too!
Ed G.
HI! (THE GHOST OF) BILLY MAYS HERE, SAYING THAT MY SUPER PUTTY WILL FILL IN THE STUBBORNEST STOMPBOX HOLES! HERE'S HOW TO ORDER!!!
BAARON
Stickers.  Stickers all the way.  Just cover them thangs up in case you want to use them again.  (I'm half-serious.)
I have a big enclosure that had way too many holes, so I covered the top with some neat looking fabric and then put a thin sheet of plexiglass over that to keep it sturdy.  Drilled holes through the plexiglass where the controls were going to go, and just held the sheet down by mounting the controls.  It looks cool, it's durable, nobody knows that there are 6 unused holes in the top of the enclosure, and I can take the plexiglass off as easily as undoing the nuts to all the pots and switches in the pedal.
B. Aaron Ennis
If somebody makes a mistake, help them understand what went wrong.  Show them how to do it right.  Be helpful.  Don't just say "you're wrong, moron."
tjmicsak
Quote from: jimbeaux on August 08, 2009, 08:41:41 PM
As Charlie Brown would say, "That's It!
Thanks Jimbeaux
