Electra problems
Started by ppatchmods, August 08, 2009, 06:25:10 PM
ppatchmods
anybody use this layout before?
[url]http://www.aronnelson.com/gallery/main.php/v/DRAGONFLY-LAYOUTS_0/album17/distortionpcb/ELECTRA+DISTORTION+layout.bmp.html/url]
I'm having a bit of trouble! by passed signal is good but very very faint effected signal. the pcb is tricky because the parts layout seems to be backwards from my etched board. are the diodes suppost to have both negatives to ground? i populated the board and realized that it was all backwards and upside down. any help would be great. thank
When your life is over, will any of this STUFF really matter?
kurtlives
One diode should have cathode to ground the other should have anode to ground.
My DIY site:
www.pdfelectronics.com
ppatchmods
made that switch earlier with the same result. it maybe a problem with my switch wiring.
