Germanium Fuzz Face debugging - please help!
Started by mr.adambeck, August 07, 2009, 08:45:28 PM
mr.adambeck
I built a germanium fuzz face using AX31C transistors from small bear.  I used the values they sent me for the resistors and the layout ended up looking like this:
The fuzz doesn't sound right.  It's very low gain on one end, and when I turn the bias the other way it just sounds kind of "farty" for lack of a better term.  It never sounds like the clips I hear of a germanium fuzz.  I've also noticed that the battery seems to get really hot, but maybe that's supposed to happen.
I've triple checked my wiring and checked the layout vs. schematic.  I can't figure out what I'm doing wrong.  I don't have a multimeter, so unfortunately I can't send you values or anything, but hopefully someone will know what this could be...
azrael
Are you sure you replaced the right resistors? You may have read their positions and used a different schematic than the one they refer to for your fuzz face.
What values did they give you, and what positions did they say they were?
Joe
The battery is not supposed to get hot. Are you sure that transistor pinout is correct? Usually the base is in the middle, maybe swap the base/collector leads?
  This means a shorted power supply, you need to find and eliminate the connection between +/-.
mr.adambeck
Quote from: petemoore on August 07, 2009, 09:46:56 PM
Any tips on how to do this?  Thanks!
Forgive me if this is a daft question, and I know this is a +ve ground pedal, but I don't see a ground on your layout?
  Unfortunately, shorts only occur in all the places except the places they don't occur.
  That's a lot of places.
  Use the DMM beep mode to determine shorting conditions, a close-in high intensity light and a magnifying glass helps view connections.
  I don't recommend it but sometimes if you can eliminate some variables by lifting a connection somewhere.
mr.adambeck
Quote from: frequencycentral on August 08, 2009, 09:46:05 AM
From how I understand it, the ground is the top strip on my layout.  Or am I wrong?  That could be the problem.
mr.adambeck
Quote from: petemoore on August 08, 2009, 10:00:13 AM
Thanks Pete -- I'll just try hunting around the circuit board later today.  Unfortunately I don't own a multimeter, so I can't use a DMM beep mode.
mr.adambeck
I had the pinout wrong on the transistors.  Switched the collector and the Emitter and it works.  SOUNDS GREAT!  I'm really really happy with the tone.  My only issue is that I have the bias on a trimpot (which wasn't shown on the layout I put in earlier, but it's on a couple extra strips at the bottom), and I might make it onto a regular pot because I like messing around with the bias to get some dirtier tones  ;D .
I really wish Small Bear would include some info with their transistors, I couldn't find anything about these ones on the web.
Anyways, now I just need to order an enclosure and box it up!  Can't wait until I can incorporate this onto my pedal board!  Since this is Positive Ground, I need to get a separate 9-volt adapter for it, right?  But I can still plug them all into the same power strip?
