AMZ Mosfet booster question
Started by Xavier, August 24, 2009, 05:40:45 AM
Xavier
I'd like to use it AS A BUFFER ONLY.
I already have it on vero, but i'm not sure if I should just jumper the volume pot..............any help?
sed
If you leave out both R5 and C5 you should get unity gain from the output. No jumper.
Daniel
rogeryu_ph
Isn't the c5(100uf) and r6(5k pot)? not the r5(2.7k)?
sed
Sorry my mistake  :icon_redface:
C5 and R6 was what I meant.
Daniel
waltk
Remove R6 and C4, and replace C5 with a .1uF cap.  Take your output from  (the new .1uF) C5 on the side that would otherwise have been connected to R6.  That will give you a non-inverting unity gain buffer.
(This is all described on the AMZ MOSFET Boost page - look at the schematic titled "Revised 9/14/2001")
