Morley Silver X-ABY-V
Started by served, August 31, 2009, 12:07:04 PM
served
Hi!
Im starting to repair my volume pedal "Morley Silver X-ABY-V". I got it in a bad shape. Guts has beed hevily moddified.
Does anyone have a picture or know how this this should have been working?
I dont know what pot it uses, i dont know how the pot is ment to work.
There is two faders inside http://en.wikipedia.org/wiki/File:Faders.jpg Like these. Both are 50k.
I would really like to get it in the correct shape, it doesnt sound good at the moment. Sucks tone and bad wiring and so on.
Maybe some one could post a picute or share some informatin, how it should work.
Or could someone explain how should it work?
I understand that, when using A or B switch, then input signal should be lead through both series faders (100k one to ground other to output) then to switch to control witch output i want.
But A and B together doesnt work in that case. A and B shoult work like this, when pedal is in the centre positsion both channels work half volume... ok ill try to figure it out.
Thanks.
A.
EDIT: Ok now i realised that with 50k ohm faders, i cant use it. Output vol is too low. And that there is no other way to use these faders...
