measuring gain and what is best
Started by bigchasbroon, September 06, 2009, 04:28:11 PM
bigchasbroon
I have 4 ac142 gemaniums. I have never meausered the hfe before and i am getting wildly different results. one tranny reached 390 and moved between that and 280 another reached only 150 and the other two were somewhere inbetween. I know that inconsistency is a feature, but im not sure which is best for which application.
I am currently building a rangemaster so im thinking lower gain, and use the others for a fuzz or somthing.
Or should I just junk them and use silicon >:(
Phorhas
Hi,
I in case you used a regular modern DMM to check their Hfe - have alook at what RG has to say on the subject. As for using Si trannies instead - I say - just build both...and then mix :)
Cheers
Electron Pusher
bigchasbroon
hmm looks like i need to build a tranny tester thanks
