Need help with resister value.
Started by trixdropd, September 15, 2009, 01:17:15 PM
trixdropd
I have 9v dc. I am feeding a relay that needs 5vdc. The coil resistance is: 166.7and it has a current draw of 30ma. What resister do i need to get me where I need to be?
The current through the resistor will be the same as the current through the relay.
The relay is dropping 5 volts so the resistor needs to drop 4 volts.
So using Ohms law R = V/I = 4/0.03 = 133.33 Ohms
I've got no idea whether wiring a relay up like this actually works in practice though.
trixdropd
Quote from: slacker on September 15, 2009, 01:49:59 PM
Thanks!! I'll breadboard it up and measure and see!!
Ripthorn
You could always stick a zener in there.  5.1V zeners are cheap and easy to find.
Exact science is not an exact science - Nikola Tesla in The Prestige
https://scientificguitarist.wixsite.com/home
trixdropd
#4
Quote from: Ripthorn on September 15, 2009, 03:32:58 PM
Will this be suitable? I know it's expensive, but I'm only using it as an example...
1n4733a
http://www.radioshack.com/product/index.jsp?productId=2049726
