Anyone know where one can get alpha track slider pots?
Started by moose23, September 05, 2009, 08:33:40 AM
moose23
Preferably in Europe. Like these ones in the Harmonic Perculator:
I've looked on all the usual sites but can't find anything even the same length from a different manufacturer. Any help would be much appreciated.
cjlectronics
What are the dimensions of the slider?  Can you find a datasheet?  Do you know the part number or series number for this slider?
moose23
I'll post the dimensions and model when I get home in  a few days. Thanks.
moose23
I can't find a data sheet or part number but the marking is Alpha A50K (Ohm). The length of the track is 38mm and the dimensions are 50mm x 12mm. I don't particularly need an alpha pot as long as the dimensions are roughly the same and it's a 50K log pot.
