How low is the output volume of the Maestro FZ1-S?
Started by gigimarga, September 29, 2009, 06:32:52 AM
gigimarga
Hello,
Sometime ago I've built a Maestro FZ1-S (http://www.generalguitargadgets.com/pdf/ggg_maestro_fz1s.pdf) and I'm still in love with it.
The only problem that I have with it is the very low output volume: I think this is about 1/2 or 1/3 (with scooped on) from the clean signal!!!
After I've built it I try to modify it, but with no luck.
So, my question is: the original has the same problem or not?
Thx all!
I have an original, and while I have not used it in a long time, I do not remember it as being too quiet.  It gave a nice boost to level in effect mode.
slideman82
Probably it'll need some bias... could be that? Check for wrong placed transistors or electrolitics.
Hey! Turk-&-J.D.! And J.D.!
gigimarga
Quote from: Mark Hammer on September 29, 2009, 11:53:46 AM
Thx Mark and slideman82 :)
Mark, when you will have sometime, could you gracefully post the voltages?
