Quick Fuzz Face Question...
Started by giantsteps, September 30, 2009, 11:13:05 AM
giantsteps
I want to add a 200-400 ohm resistor to one of the lugs of the 1k gain pot in my fuzz face. Though there are 2k pots available, I'd rather make this "quick fix" until I am able to order a 2k.
Not to add more gain per se, but to change the range of gain options. I'd also like the "sweet spot" that I set it at to be a little more to center.
Which lug would I attach the resistor to: the one leading from the transistor, the one leading to ground, or the one leading to the cap?
Thanks,
Chris
John Lyons
The 1k pot sets the bias as the 1K resistoance is fixed
from the emitter to ground through the 1K.
The pot varies Bypass of the cap from the emitter
to ground.
Tell us what you want to do and we can tell you how to do it.
John
Basic Audio Pedals
www.basicaudio.net/
Gus
in the schematics link at the top of this page for years
http://www.diystompboxes.com/pedals/gusFuzzFace.gif
Also look at the Vox fuzz schematic in the tech of the ff at geofex.
giantsteps
I guess what I'd like to do is alter the gain range so that the range of the gain pot goes from 200 ohm to 1.2k instead of 0 oh to 1k.
I'm just not sure which end of the gain pot to insert the resistor.
BAARON
If you want to make the gain pot go from 0%-80%, put the resistor between the pot and Q2.
If you want to make the gain pot go from 20%-100%, put the resistor between the pot and ground.
Putting a bigger pot in there won't increase gain anyway.  It'll barely affect the 100% position on the knob, but it'll make the 0% position cleaner.
B. Aaron Ennis
If somebody makes a mistake, help them understand what went wrong.  Show them how to do it right.  Be helpful.  Don't just say "you're wrong, moron."
