What Power Supply Voltage?
Started by Greeny009, October 11, 2009, 12:11:15 AM
Greeny009
once ive designed a circuit how do i determine what voltage power supply would be suitable?
peps1
Ohm's Law
(Most people start with the voltage, and make the circuit around it)
Quote from: Greeny009 on October 11, 2009, 12:11:15 AM
It is in general backwards to do that in the way you've described, designing a circuit, then picking a suitable power supply.
Rather, the power supply voltage is nearly always a given starting point, and you make the circuit work within the available power supply.
