Ts-808 problem need help
Started by differo, October 26, 2009, 06:43:29 AM
differo
Hi everyone,
I just built my first diy pedal (layout & schematics from tonepad.com awesome site!!) and it works (etched my board..). But!
the sound is not good at all - it sounds like the battery is drained (its not..) if you know what i mean - like some germanium fuzzes,
all the components are stock, all the pots are doing what they should and when i lower the drive it cleans out the signal nicely
but again, when the drive is up it distorts the signal indeed but its kinda cranky, like its disappearing for a (very) short while.
hard to explain but I was hoping that someone might encounter this problem sometimes and might recognize it.
Thanks for any ideas where to search for a problem.
My youtube channel:
http://www.youtube.com/user/BeToneful
Rebote2.5,MXR dist+,DrBoogie,BSIAB2,Ross Compressor&Phaser,MXR EnvFilt &Noise Gate,TS808,Condor CabSim,SansampGT2,Fraverb,Small Clone,TremLune,ValveCaster
yyz_2112
I have the same problem with my build, also from the tonepad layout. Not my 1st build by far, but the issue is the clipping is very farty and buzzy anywhere past 1/3 of the gain level.
dougman0988
I noticed in the build that there is no bypass capacitor from 9v to ground.  I'm assuming other people have built this pedal and got it to work fine, but it might be worth trying.  Put a small (maybe 100-200pF) across 9v and ground.  It should help keep the circuit stable when at high gain, which is when the problem occurs.  Another thing to check might be the ground connection.  How is the grounding done for this build?  Make sure its a good connection.
www.pickuptheguitar.com
Guitar lessons, music theory, audio projects
bipedal
I've had good success using Tonepad's TS808 layout, no changes needed.
Try the usual troubleshooting steps, check for reversed transistors, missed traces and solder bridges.
Can you post a pic of your build?
"I have gotten a lot of results. I know several thousand things that won't work." -T. Edison
The Happy Household; The Young Flyers; Derailleur
differo
I fixed it. Now, the problem is, which i really hate, is that when i fix something and i do not know how i did it. :) the reason for this is that i did some debugging and changed stuff sometimes without checking: checked all solder joints (re-solder) and not testing the circuit after EVERY small fix. I think thou that the electrolyte cap. in the input stage did the magic, i changed it to another one (same capacity but different brand) and the gain pot seemed to have bad solder joint. Now it works like it worked from the beginning. I'm gonna try to  add a small cap between the 9v and the ground.
Now another question about overdrive-type of effect in general: how do you proceed with the shielding the signal from/to jacks/switch/PCB? this is kinda a foggy area - I always shield it from the guitar side, but maybe it is sufficient with the plain wire on the output side?? It's hard to measure the noise introduced if a cable is not shielded on the output side. It just doesn't seem to have any effect but then again..
What are your experiences/practice?
My youtube channel:
anchovie
I've never used shielded cable in a TS or any overdrive of similar gain, just a metal enclosure. I've only needed it for high-gain circuits like the Dr Boogey that risk oscillation when the input and output are connected close together on the footswitch.
differo
thank for that, I'll try to see if there is a difference in wiring with standard wire only. it's kinda messy with shielded cables they just take too much space! :)
My youtube channel:
  If it's workin' I wouldn't change it until I 'had' to.
  Shielded wiring won't hurt, but for the troubles/benefits it's not worth messing with.
