X-Over Fuzz idea
Started by Dragonfly, July 08, 2008, 01:25:37 PM
Dragonfly
A simple fuzz idea that uses crossover distortion combined with transistor saturation in order to achieve what "should be" a unique fuzz sound. This is an untested idea, but the values should be close. If there is too much "splat", then you should be able to put a resistor (maybe 100k-220k-ish)after the 1N34a diodes to limit the second transistors over-saturation. Anyway, if you breadboard it, report back on your findings...
Gus
Diode section
Look at the boss HM2 schematic
Dragonfly
Quote from: Gus on July 08, 2008, 03:00:45 PM
Diode section
looks like boss is combining diodes to ground as well as diodes in the same type setup as above (as well as in the feedback loop of a op amp)
Any particular reason for the 10k's on either side ?
gigimarga
Anyone still has the schematic?
I've lost mine...
gigimarga
