Muff Fuzz (Adv'd DIY Effect Pedal)
Started by oldrocker, August 11, 2006, 10:24:57 PM
oldrocker
I recently received the IndyGuitarist Advanced DIY Effect Pedal Book.  It showed an opamp Muff Fuzz circuit with a variable 470k resistor across the input and output of the first opamp.  I had a terrible fizzle when the notes would fade out on mine and I thought I would try and see if lowering the resistance here would help.  I didn't use a pot but I think I'll evenually add one.  I ended up using a 220K here and sure enough it almost eliminated it.  The variable resistor the the Indyguitarit book was the first time I saw that used.
oldrocker
I had read that to resolve this situation was to put a resistor across the diodes (470K) and that the fizzle is a normal characteristic of the opamp Muff Fuzz.  I'm not sure why a gated fizzle would be desirable in an effect but to each his own I guess.  I was thinking if pots were added at both these two points it would give the MF a more adjustable fuzz.  Anyone try this?
WGTP
The size of the input resistor determines gain and input impedance which effects the low roll off with the input cap and the highs.  Using a low value 10K, produces a really midrangey Rockman sort of sound.  Check out the Mockman at ROG.  100K is std. on the original, and I like 220K as well.   The 220K lowers the gain, but gives it more of an amp like distortion, rather than a fuzz.  Might raise the first feedback loop resistor to 1M to recover some gain if needed.  I think the original gates as a noise reduction technique.  Gus Smalley had several mods posted that were pretty cool including these mentiioned.  Try some LED/SI/GE combos for more variations.  The LED's sound nice and reduce the noise coming thru.   :icon_cool:
Stomping Out Sparks & Flames
roseblood11
Quote from: WGTP on August 14, 2006, 01:51:45 PMGus Smalley had several mods posted that were pretty cool including these mentiioned.
Does anybody know that link? Or anything about those mods?
I really wanna get rid of the sputtery decay...
Immo
CynicalMan
Quote from: roseblood11 on October 24, 2009, 05:29:42 PM
Immo
http://www.generalguitargadgets.com/diagrams/gus_muff_mod1.gif
http://www.generalguitargadgets.com/diagrams/gus_muff_mod2.jpg
roseblood11
Thanx!
The next step is to understand, which mod will solve that problem.
I think it´s the different IC and the changes in the voltage divider?
gigimarga
I have an old question about Muff Fuzz: is there a resistor/pot of 1M in the feedback loop of the second opamp or not (only diodes) ?
Some schematics say yes, another ones say no :)
ode2no1
i built a muff fuzz earlier this year and wanted to pull my hair out because i couldnt get rid of that crackly gated decay. i just scrapped it and built a rangemaster into that one knob enclosure.
WGTP
IIRC the original didn't not have a resistor across the diodes in the second op amp.  470k or 1M work well to make this into a more usable distortion.  Here are some mods I did mostly based on Gus' mods.   :icon_cool:
http://www.aronnelson.com/gallery/main.php/v/WGTP/AlteredMuff.jpg.html?g2_imageViewsIndex=1
gigimarga
Quote from: WGTP on October 26, 2009, 11:29:05 AM
Thx a lot WGTP!
I've built mine following a schematic of analogguru, which traced it after an unit from 1977, and which had a 470K resistor across the didodes (and values of another parts are a little different).
