Morley JD-10 speaker simulator
Started by aron, October 28, 2009, 03:52:51 PM
aron
We've talked about this a long time ago, but I just wanted to say that the JD-10 is an amazing little box. I wanted to make smaller pedalboard just for playing through my keyboard system, so I took out the JD-10 to start with. The board is configured like this with my "spare pedals".
guitar->volume pedal->MXR dynacomp->JD-10->Memory Man->Verbzilla.
All I can say is that it sounds good - really good. I used it in classic mode with the speaker simulator on. I set it so that when the volume pedal is down all the way, I get overdrive and smooth sustain. The MXR output is all the way up and the sensitivity turned very low. If I want "more" all I do is turn the sensitivity up.
This setup kills my original POD for direct playing - the feel is so much better.
The schematic:
http://www.diystompboxes.com/smfforum/index.php?topic=18372.0
