change an s-taper?
Started by jdub, November 07, 2009, 02:22:19 PM
jdub
Howdy-
Is it possible to change the taper of a Hot Potz wah pot (s-taper) to something approximating an audio taper? Is it a matter of fiddling with resistor values between the outer lugs and the wiper?
A boy has never wept nor dashed a thousand kim
zombiwoof
I thought I'd just let you know that Antique Electronics (tubesandmore.com) sell a few wah-type pots in various values that are linear taper.  They're only about $8-9.  Might be easier to change to audio.
Al
jdub
Thanks, Al.  I was kind of thinking along those lines myself...I was just curious if it could be done relatively easily :P
