Where to buy push/push audio pots?
Started by boogietone, January 01, 2012, 12:34:53 PM
boogietone
Need to replace the pots in my franenstrat. Looking for 250k and 500k audio push push pot/switches. Any recommendations?
An oxymoron - clean transistor boost.
boogietone
I am probably going to end up going with the push pull from SB. But, I am looking first for push push switches. I have found some but they run 10+ bucks. As usual I am surprised by what is hard to find.
Greenmachine
I don't like push/push because I had one break down over time - more complicated mechanism than push/pull.
G. Hoffman
ALLPARTS has push/pull and push/push pots in all the standard guitar values.
I'd also suggest push/pull, just for the reliability issue.
Gabriel
smallbearelec
Unfortunately, guitars often require a longer bushing than cast aluminum chassis. By all means try the push-pull style that I have; you can return unsoldered if they don't fit. But you may have to pay the stupid prices at the guitar specialty-parts places until SBE gets into guitar pots. Could happen, but not tomorrow...we would need more space.
CynicalMan
If you want something easier to use than push/pull, just put in a hole for a toggle or button switch. If you're on a strat, that should be easy to install, and toggle switches are easier to wire than pot switches.
Also, if you're modding a strat and you're just going through a plastic pickguard, you shouldn't need the longer bushing. But if you're going through wood, you do need the specialized guitar pots most of the time.
DavenPaget
Quote from: CynicalMan on January 02, 2012, 08:55:48 AM
Yep . I took out both of my tone pots  :icon_lol:
Next time i'll drill 2 hole in my strat for my tone pots  :icon_mrgreen:
Hiatus
