Dragonfly JFET Boost
Started by sevenisthenumber, November 13, 2009, 07:17:19 PM
sevenisthenumber
I built up the super simple
I love it! It has a nice bite! How could one simply adjust some of the upper frequencies?
Tanks!
sevenisthenumber
i thought that but was wondering if a simple resistor adjustment might let me change the highs/lws.
compuwade
I believe C2 will change the boosted frequency. I'm not sure how the rest of the circuit will react to it though.
CynicalMan
Quote from: compuwade on November 14, 2009, 03:22:41 AM
At 10u, this circuit is boosting all audio frequencies equally. Increasing its value wouldn't do anything and reducing it would reduce bass. A way of reducing treble would be to add a capacitor from the gate to ground.
John Lyons
Yes, with the same parts count there is only a way to decrease bass.
Make C2 smaller and you increase the treble boost.
With more parts
Put a 10K resistor after C1 and a .002 cap to ground and
take the output off the junction or the two and to the volume
control and you'll cut a little high end.
Adjust the resistor larger and you'll cur more highs.
Make the cap bigger and you'll change the freqs cut (slope).
John
Basic Audio Pedals
www.basicaudio.net/
Der Groovemeister
Better build his Sparkle boost. That sounds awesome! It is unimprovable.
"What do you mean, dynamics? I'm already playing as loud as i can!"
