Megadrum Diy edrum module
Started by ubaid88, December 25, 2009, 05:47:47 AM
ubaid88
I know this not related guitar but this is a great dsp diy project to build. Many guitarist also do drums, so it might interest them.
It was my first dsp project.
www.megadrum.info
http://www.youtube.com/watch?v=xvIhtFoODsI (This is not my video ;) )
Here are the main features of the MegaDrum drum trigger
   * Atmega based. You can choose Atmega8 (obsolete), Atmega32, Atmega324P or even Atmega644. Several versions of firmware are provided for 12MHz, 16MHz or 20MHz versions of these chips.
   * No need for an expensive programmer. Programming is done via a simple cable.
   * MegaDrum firmware can be upgrade over Sysex so you won't need a programmer after an initial bootloader firmware has been programmed.
   * USB powered. No need for a separate power supply.
   * Different MIDI I/O options: standard MIDI or one of optional USB Boards: PIC18F2550 true USB MIDI, USB over FTDI232(obsolete), USB over AVR-CDC (obsolete,Atmega8 based)
   * Potentiometers free design. You don't need pots at all and this saves quite some money.
   * 9 levels input gain set individually for each channel.
   * Supports Dual Zone Piezo-Switch pads.
   * Supports 3 zone Roland style cymbals (e.g. CY-12/CY-15).
   * Sopports 3 zone Yamaha style cymbals (e.g. PCY150S).
   * SysEx support. MegaDrum can be controlled from a computer.
   * 4 Crosstalk suppression groups with individual crosstalk suppression levels in each group.
   * Can save 2 or 4 configs and 7 or 13 Drum Maps (depending on the MCU type).
   * Individual midi channel, dual/single pad, auto/manual sensitivity and curve settings for every channel.
   * Velocity curves for each individual channel can be compressed and shifted.
   * CC Choke support on every Dual Zone piezo/switch pad or 3 zone cymbals.
And here my megadrum
More on www.megadrum.info
