lm386 (not 383) as a preamp?
Started by dmartn149, March 15, 2010, 04:50:32 PM
dmartn149
I am re-posting this question because I got the subject wrong the first time.
This isn't really a "stompbox " question, it's an amp question, but I bet lots of you know the answer. Anyway, I am new to building my own devices, and the first thing I built without a kit or pcb was an lm386 amp. It doesn't give enough clean headroom, so I was thinking I would build a tda2003  amp. (there is a kit on ebay for $5.00)  My question is, can I use the lm386 as a preamp?
John Lyons
Yep. Smashdrive, Lovepedal Purple Plexi and many others are pre amps based on the 386.
Basic Audio Pedals
www.basicaudio.net/
phector2004
wait... smashdrive is a preamp??
i'm planning on building a smashdrive (unless you'd suggest a better high-gain pedal!)
i can still use it as a pedal directly into my amp, right?
Electron Tornado
The 386 chip is an audio amp, so yes, it can be used in amp (Noisey Cricket) and pre-amp applications. It can also be used in a pedal. If you're going to build a pedal with the 386, take a look at the datasheet for the chip as well as some other pedals that use it.
"Corn meal, gun powder, ham hocks, and guitar strings"
Who is John Galt?
darron
the lm386 is the amp used in the ruby. you can get low volume practice amp levels out of it only. i was over-driving a 0.25W speaker with one, so maybe something a tiny bit bigger like 5watt?
Quote from: phector2004 on March 16, 2010, 12:30:24 AM
(going OT... i can suggest the BSIAB2 [aka BSIABII] or its big brother the dr boogie as an excellent high [HIGH!] gain pedal for amp-like preamp modelling to run into an amp.)
raulgrell
IMO, the Krank Distortus Maximus is an improvement on the smash drive (also based on the LM386), whether it was intentional or not... It's basically the smash drive with a different tone stack and a booster in front of it. I recommend trying different boosters, as each gives the pedal a different kind of character.
IIRC, a forum member made a version of it called the "burning crunch" which makes use of some smart mods that make it sound a bit better... There was also a pedal that used two LM386 stages in series which sounded pretty damn good... been experimenting with the idea, toneshaping between/before stages and it's a surprisingly useful design concept.
I've seen the LM386 used a clean booster too... the little breakup it had was actually quite pleasing to the ear...
phector2004
thanks for the ideas...
i feel a bit guilty hijacking this thread :P
sorry!
dedguy
The Krank uses a lm386-3, which if I'm not mistaken has more gain than a regular lm386.
dmartn149
Quotei feel a bit guilty hijacking this thread
Don't feel guilty. I 'm glad to find out that the lm386 has so many applications. Here is the amp kit that I ordered.
http://cgi.ebay.com/Audio-Power-Amplifier-20W-2x-TDA2003-Assembling-kit_W0QQitemZ230446223553QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item35a7aa50c1
Can't beat the price.
Thanks for all the input.
raulgrell
Quote from: dedguy on March 16, 2010, 04:55:51 PM
I think the suffix is related to optimum/maximum supply voltage actually... whether that has an effect on gain, I'm not sure...
dedguy
Okay so maybe gain was the wrong term.  The -1 with a 6v power supply has a output of 325 mW on average, whereas the -3 has a output of 700 mW with a 9v power supply. I hope that clears up any confusion.
raulgrell
Quote from: dedguy on March 16, 2010, 09:57:12 PM
Boom! That's what it was =)
